*ellipsoid
Creates a solid in the shape of an ellipsoid.
*ellipsoid center=<value> a_dir=<value> b_dir=<value> a=<value> b=<value> c=<value>
HyperMesh Tcl Modify Command
Consider the general equation of an ellipsoid centered at as
This ellipsoid’s principal axes are aligned with x, y and z directions. In this command, an ellipsoid is created whose principal axes are aligned in any specified direction. User defined directions are given for the principal axis that is associated with a value in a_dir, and the principal axis for b value in b_dir values. The principal axis for c value is determined by the other two directions.
- center=<value>
- The center location of the ellipsoid.
- a_dir=<value>
- The principal axis direction associated with ‘a’ value. A vector input is expected.
- b_dir=<value>
- The principal axis direction associated with ‘b’ value. A vector input is expected.
- a=<value>
- The ‘a’ value in the ellipsoid equation.
- b=<value>
- The ‘b’ value in the ellipsoid equation.
- c=<value>
- The ‘c’ value in the ellipsoid equation.
Examples
To create an ellipsoid solid centered at (1,1,1) with principal axis for ‘a’ as (1,1,0),
with principal axis for ‘b’ as (0,0,1), a=4, b=5, and c=6 values:
*ellipsoid center="1.0 1.0 1.0" a_dir="1.0 1.0 0.0" b_dir="0.0 0.0 1.0" a=4 b=5 c=6Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2025
