*sl_meshsurfaces
Performs feature-based meshing of surfaces using an XML config file.
*sl_meshsurfaces mark_id file reserved
HyperMesh Tcl Modify Command
- mark_id
- The ID of the mark containing the surfaces to mesh. Valid values are 1 and 2.
- file
- The full name and path to the XML config file containing the mesh parameters.
- reserved
- Reserved for future use. Must be set to 0.
To mesh all surfaces using the config file c:/temp/config.xml:
*createmark surfs 1 all
*sl_meshsurfaces 1 c:/temp/config.xml 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
