*updatestackedentities
Stacks composites entities in a hierarchy.
*updatestackedentities ?option1=<value1>? ?option2=<value2>? ... ?optionN=<valueN>?
HyperMesh Tcl Modify Command
This command updates the hierarchy of composite entities. It can be used to stack plies under sequences and laminates, sequences under laminates and sublaminates under interface laminates. It can also be used to unstack any child entities.
- entitytype=<value>
- The entity type of the parent or target stack entity. If method argument is present, this is the parent entity type. Otherwise, this is a target from which the appropriate parent will be determined. If the specified type is a ply, sequence or laminate entity, the children in entitylist will be handled for stacking. Otherwise, the children in entitylist will be unstacked from their current parent.
- id=<value>
- The ID of the single parent or target stack entity. If method argument is present, this is the parent entity type. Otherwise, this is a target from which the appropriate parent will be determined.
- entitylist=<<entitytype1>={id1 id2 … idN} <entitytypeN>={id1 id2 … idN}>
- List of child entities to be stacked or unstacked. Plies and sequences are accepted are valid entity types. Ids can be passed as a single value or as a list for the given type. N entitytype={ids} pairs can be passed.
- method=<value>
- Specifies method in which entitylist children should be stacked. If method argument is present, entitytype and id arguments above specify the parent stack entity. Otherwise, entitytype and id arguments specify a target stack entity, where the command will internally determine the appropriate parent (for example, if target is stacked ply, the parent laminate will be used as parent).
- index=<value>
- The index of the stack parent incoming children in entitylist will be stacked if method=insert. 0 specifies the top of the stack.
- reorderinputbyindex=<value>
- If true, reorders incoming children in entitylist such that they are ordered in the same way as displayed in the current browser. Otherwise, children are stacked in exactly the order specified in entitylist. Default is false.
Examples
Append plies 5, 6, 7, 8 into parent laminate with ID
1:
*updatestackedentities entitytype=laminate id=1 entitylist="plies={5 6 7 8}" method=append
#Ply ids in laminate 1 before stacking: 1 2 3 4
#Ply ids in laminate 1 after stacking: 1 2 3 4 5 6 7 8Insert plies 5, 6, 7, 8 into parent laminate with ID 1 at index
1:
*updatestackedentities entitytype=laminate id=1 entitylist="plies={5 6 7 8}" method=insert index=1
#Ply ids in laminate 1 after stacking: 1 5 6 7 8 2 3 4Stack plies at ply
target:
*updatestackedentities entitytype=plies id=2 entitylist="plies={5 6 7 8}"
#Ply ids in laminate 1 after stacking: 1 2 5 6 7 8 3 4Unstack all plies from laminate ID
1:
*updatestackedentities entitytype=laminate id=1 entitylist="" method=replace
#Ply ids in laminate 1 before stacking: 1 2 3 4 5 6 7 8
#Ply ids in laminate 1 after stacking: {}Unstack plies 1, 3, 6, 7 from laminate ID
1:
*updatestackedentities entitytype=laminate id=1 entitylist="plies={1 3 6 7}" method=remove
#Ply ids in laminate 1 after stacking: 2 4 5 8Stack combination of plies and sequences in laminate
parent:
*updatestackedentities entitytype=laminate id=1 entitylist="sequences=6 plies={5 6 7 8} sequences=7" method=appendStack plies 9, 10 in sequence ID
1:
*updatestackedentities entitytype=sequences id=1 entitylist="plies={9 10}"Stack sublaminates 2, 3 in interface laminate ID
1:
*updatestackedentities entitytype=laminate id=1 entitylist="laminates={2 3}"Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2024
