*removeelemsfromcontactsurfusingnodes
Removes elements from a contactsurf using face nodes.
*removeelemsfromcontactsurfusingnodes name elem_mark_id node_mark_id
HyperMesh Tcl Modify Command
Removes elements from a contactsurf using face nodes. If all elements are removed the empty contactsurf still exists.
- name
- The name of the contactsurf.
- elem_mark_id
- The ID of the mark containing the elements to remove. Valid values are 1 and 2.
- node_mark_id
- The ID of the mark containing the nodes defining the face nodes of the elements to remove. Valid values are 1 and 2.
To remove elements 100 and 101 from the contactsurf "test" for the specified face defined by the nodes on mark 2:
*createmark elems 1 100 101
*createmark nodes 2 201 202
*removeelemsfromcontactsurfusingnodes "test" 1 2
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
