*surfacemarksplitwithsurface
Splits a group of surfaces with another surface.
*surfacemarksplitwithsurface mark surface
HyperMesh Tcl Modify Command
- mark
- The ID of the mark containing the surfaces to be split.
- surface
- The surface used to split the other surfaces.
To split surfaces 10 and 20 with surface
5:
*createmark surfaces 1 10 20
*surfacemarksplitwithsurface 1 5 Errors
None.
