*movesubmodel
shortDescription
*movesubmodel source_submodel_type source_filename target_submodel_type target_filename
HyperMesh Tcl Modify Command
longDescription
- source_submodel_type
- Use solversubmodel for a solver submodel or includefile for an include file.
- source_filename
- The name of the source file to move into the tree.
- target_submodel_type
- target_filename
- The name of the new target file.
Examples
To move the solver submodel with name Part1 to include file with name EngineInclude:
*movesubmodel "solversubmodels" "Part1" "includefiles" "EngineInclude"
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
