*panelcreation
Creates a panel entity.
*panelcreation mark_id name findPanel
HyperMesh Tcl Modify Command
- mark_id
- The ID of the input elements. Valid values are 1 and 2.
- name
- The name of the panel entity.
- findPanel
- 0 - Directly create the panel entity using the input elements
Examples
Create a panel named panel1 from elements
1-10:
*createmark elems 1-10
*panelcreation 1 panel1 0Find panel entities from elements
1-10:
*panelcreation 1 panel1 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020
