*metadatamarkremove
Removes metadata from the specified mark of entities.
*metadatamarkremove entity_type mark_id name
HyperMesh Tcl Modify Command
- entity_type
- The type of entities contained on the mark.
- mark_id
- The ID of the mark containing the entities to which the metadata will be removed. Valid values are 1 and 2.
- name
- The name by which the metadata is referenced.
To remove metadata named Int_Val from elements
1-100:
*createmark elems 1 1-100
*metadatamarkremove elems 1 "Int_Val"Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
