*displayelementsbyproperty
Controls the display of elements that have either a direct, indirect or mixed property assignment.
*displayelementsbyproperty mode type
HyperMesh Tcl Modify Command
- mode
- The mode to control the element display. Valid values are:
- on - Turn on the elements.
- off - Turn off the elements.
- reverse - Reverse the display of the elements (if off, turn on and if on, turn off).
- isolate - Isolate the display of the elements (turn off all others).
- type
- The property assignment type to use for selecting the elements to display. Valid
values are:
- 0 - Direct property assignment.
- 1 - Indirect property assignment.
- 2 - Any property assignment.
To turn on the display of all elements with a direct property
assignment:
*displayelementsbyproperty on 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0
