*realizehmentity
Realizes HyperMesh entities.
*realizeentity entity_type mark_id ?targetentitytype=<value>?
HyperMesh Tcl Modify Command
Realizes HyperMesh entities. Constraints are realized to elements or groups based on targetentitytype. Solvermasses are realized to nonstructural mass properties in Abaqus.
- entity_type
- The type of entity to realize. Currently supported entity types are constraints and solvermasses.
- mark_id
- The ID of the mark containing the entities to realize. Valid values are 1 and 2.
- targetentitytype=<value>
- The type of the target entity. Valid values are elements and groups. Currently only supported for constraints.
Examples
To realize all constraints to elements:
*createmark constraints 1 all
*realizehmentity constraints 1 targetentitytype=elemsTo realize all solvermass
entities:
*realizehmentity solvermassesTo realize solvermass entities on
mark:
*createmark solvermasses 1 "by id only" 1 2
*realizehmentity solvermasses 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2022
2022.2 - Added support for solvermasses.
