*quad_split
Split warped quads into trias such that it does not create intersections.
*quad_split entity_type mark_id
HyperMesh Tcl Modify Command
- entity_type
- The type of entity to modify. Must be set to elements.
- mark_id
- The ID of the mark of quads to split. Valid values are 1 and 2.
Examples
To split displayed quads:
*createmark elems 1 displayed
*quad_split elems 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020.1
