*morphapplyfesolver
Invokes the finite element solver solution for all perturbed domains with a limited number of elements.
*morphapplyfesolver
HyperMesh Tcl Modify Command
This command will invoke a finite element solver, specified by the fesolver parameter, and solve for the internal perturbations for all domains which have fewer elements than that specified by the fesolverlimit parameter using enforced displacements applied at the domain handles, edges, and/or faces. The command will either use the properties and materials specified for the mesh or generate properties and materials automatically depending on the feuser parameter.
This command has no arguments but uses several parameters when it is executed which are described below. These parameters can be updated using the *morphupdateparameter command.
- fesolver
- 0 - Linear solver (OptiStruct)
- fesolverlimit
- Domains containing less than this number of elements will be updated.
- feuser
- 0 - Use automatically generated properties and materials
*morphapplyfesolverErrors
# Handle error
}Version History
10.0
