*modent_deletebymark
Deletes a mark of modular entities.
*modent_deletebymark entity_type mark_id keep_contents
HyperMesh Tcl Modify Command
- entity_type
- The type of modular entity to delete. Currently only supported for subsystems.
- mark_id
- The ID of the mark of modular entities to delete. Valid values are 1 and 2.
- keep_contents
- 0 - Delete all contained entities
Examples
Delete subsystems 4, 6 and 8 and move the contents under the main
include:
*createmark subsystems "by id only" 4 6 8
*modent_deletebymark subsystems 1 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020
