*CE_AddLinkEntitiesDirectByRule
Allows the user to add link directly to the connectors without considering tolerance or number of layers.
*CE_AddLinkEntitiesDirectByRule mark_id link_type link_rule link_state link_string_array link_number_of_strings extra_link_integer_array extra_link_number_of_integers create_group
HyperMesh Tcl Modify Command
- mark_id
- The ID of the mark of connectors to update. Valid values are 1 and 2.
- link_type
- The entity type to be added to the connectors as links.
- link_rule
- The rule by which the link entity is added to the connector. If the rule is specified, the modification is performed in accordance with the rule. For example, a value of 2 requires link IDs to be specified for link_string_array. Valid values are:
- link_state
- The state of the link entity which is to be added:
- link_string_array
- A string array containing the list of link IDs/names/UIDs to be added directly to connectors, created using*createstringarray. This must be set to 1.
- link_number_of_strings
- Integer indicating the size (number of strings) in the link_string_array created using *createstringarray.
- extra_link_integer_array
- An integer array containing the list of extra link additions allowed for spots and seams, created using*createarray. This must be set to 1.
- extra_link_number_of_integers
- Integer indicating the size (number of integers) in the extra_link_integer_array created using *createarray.
- create_group
- 0 - Add the newly chosen links separately to the connector
Examples
Add two component links (ID 1 and 2) directly to connector ID 2 of type spot using without creating a group link:
*createmark connector 1 2
*createstringarray 2 1 2
*createarray 2 2 2
*CE_AddLinkEntitiesDirectByRule 1 comps 2 1 1 2 1 2 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
