*clearpreservednodes
Clears the selected nodes that were marked as preserved.
*clearpreservednodes mark_id
HyperMesh Tcl Modify Command
This command clears the selected nodes that were marked as preserved.
- mark_id
- The ID of the mark containing the preserved nodes to clear. Valid values are 1 and 2.
Examples
To clear preserved nodes
1-4:
*createmark nodes 1-4
*clearpreservednodes 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
13.0
