*elementqualitysmoothnodesnew
Smooths/optimizes nodes of selected elements.
*elementqualitysmoothnodesnew elem_mark_id nodes_mark_id algorithm target_qi max_iterations time_limit
HyperMesh Tcl Modify Command
This command smooths/optimizes nodes of selected elements.
This command only functions between an *elementqualitysetup command and an *elementqualityshutdown command.
Current element quality criteria for optimization must be set before using this command. The command may be applied at any time without resetting the current quality criteria.
- elem_mark_id
- The mark ID containing the elements to smooth. Valid values are 1 and 2.
- node_mark_id
- The mark ID containing any anchor nodes. Valid values are 1 and 2.
- algorithm
- 0 - Autodecide.
- target_qi
- The target QI value, when algorithm is set to 3.
- max_iterations
- The maximum number of iterations, when algorithm is set to 3.
- time_limit
- The maximum time limit, when algorithm is set to 3.
To smooth elements 1-100 using QI optimization with a target QI of 0.2 using quality
criteria from a
file:
*readqualitycriteria c:/criteria/mycriteria.txt
*createmark elems 1 displayed
*elementqualitysetup 1
*createmark elems 1 1-100
*elementqualitysmoothnodesnew 1 1 3 0.2 5 0
*elementqualityshutdown 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
13.0
