*syncpropertybeamsectionvalues
Copies the beam section values to property values. Currently valid only for Nastran and OptiStruct.
*syncpropertybeamsectionvalues mark_id
HyperMesh Tcl Modify Command
- mark_id
- The ID of the mark containing the properties. Valid values are 1 and 2.
Examples
To copy beam section values to all 1D properties to which the beam section is attached:
*createmark props 1 all
*syncpropertybeamsectionvalues 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
