*solidmap_solids_set_mapface
Sets the surface shared by the 4 input points to the mapped type within a multiple-solid solidmap command block.
*solidmap_solids_set_mapface point_id1 point_id2 point_id3 point_id4
HyperMesh Tcl Modify Command
This command is used to set the surface shared by the 4 input vertices to the mapped type with the input vertices as the corners. The 4 vertices must be distinct. If more than one surfaces share the 4 vertices, the resulting surface for type setting is random. The command has effect only for surfaces for which the mesh type is free to change (for example, not an along face of a solid). This command can only be called between a *solidmap_solids_begin and *solidmap_solids_end command pair.
- point_id1
- The ID of the first corner vertex.
- point_id2
- The ID of the second corner vertex.
- point_id3
- The ID of the third corner vertex.
- point_id4
- The ID of the fourth corner vertex.
*createmark solids 1 32 41
*solidmap_solids_begin 1 0 2.0
*solidmap_solids_set_mapface 10 11 12 13
*solidmap_solids_endErrors
# Handle error
}Version History
10.0
