*coarsen_and_decimate_mesh2
Performs mesh coarsening and decimation on selected components.
*coarsen_and_decimate_mesh2 comps_mark_id nodes_mark_id failed_comps_mark_id elem_size elem_type feature_angle max_diameter options string_array number_of_strings
HyperMesh Tcl Modify Command
Performs mesh coarsening and decimation on selected components. The ability exists to specify sacred nodes that will be maintained after coarsening/decimation. The command has additional options that allow adjusting the element size for small components and deleting elements of small components.
- comps_mark_id
- The ID of the mark containing the input components. This must also include any 1D multi-leg rigid elements that will be processed by the options flags. Valid values are 1 and 2.
- nodes_mark_id
- The ID of the mark containing any nodes to be treated as sacred/fixed. These nodes must belong to the initial mesh. These nodes will be maintained during coarsening/decimation. Valid values are 1 and 2.
- failed_comps_mark_id
- The ID of the mark to store any failed components. Valid values are 1 and 2.
- elem_size
- The element size to use for coarsening/decimation. This must be larger than the initial mesh size.
- elem_type
- Element type flag to generate for the coarsened mesh. Valid values are:
- 0 - trias
- 1 - quads
- 2 - mixed
- 3 - right trias
- 4 - quads only
- feature_angle
- This specifies the maximum angle between the normals of two connected elements. This value is ignored for shell elements. For 3D elements, the appropriate free faces of shell elements are created and meshed with the given feature angle. This value is also used to construct the connected edges for the failed components. Then these components are coarsened in a second attempt.
- max_diameter
- This option specifies the maximum hole diameter that will be filled by the coarsening operation. The default value is 0.0 (do not fill any holes).
- options
- Flags that specify various methods of pre-processing and post-processing of 1D and 2D
elements. Bit values are used and the value is calculated as (Bit0 + 2*Bit1 +
4*Bit2 + 8*Bit3 + 16*Bit4 + 32*Bit5 + 64*Bit6).
- Bit0
- 0 - Do not utilize this option.
- Bit1
- Bit2
- Bit3
- Bit4
- Bit5
- Bit6
- string_array
- The ID of the string array that contains the additional option parameters that allow tuning of algorithms to make adjustments to the element size. The string array is created using the *createstringarray command. This should always be set to 1.
- number_of_strings
- Integer indicating the size (number of strings) in the string array created using *createstringarray. If no strings are provided, set this to 0 and the default algorithms will be used.
Examples
Create a coarsened and decimated mesh with mixed type elements of element size 30 using all
components. Put failed components on mark ID 2. Keep node IDs 16 and 27 as anchor nodes.
Ignore all internal loops with diameter less than 65. If the model has solid elements,
create free faces of shell elements and mesh them with a feature angle of 45 degrees. Delete
selected 1D elements not sharing sacred nodes before meshing (option Bit0=1). Delete
selected free 1D elements after meshing (option Bit1=1). If the model has rigidlink/RBE3
elements, delete any free legs in the input components (option Bit2=1). Convert 1D elements
to plot elements after meshing (option Bit3=1). The options are computed as 1 + 2 + 4
+ 8 = 15. Delete shell and solid elements of components with maximum bounding box
dimension less then 25.0. Use a prior small components mesh with factor 3.0. Use iterative
component element size reducing with factor
1.5:
*createmark components 1 "all"
*createmark nodes 1 16 27
*createstringarray 1 "delete_comp_size 25.0 max_compsize_factor 3.0 elsize_autoreduce_factor 1.5"
*coarsen_and_decimate_mesh2 1 1 2 30.0 2 45.0 65.0 15 1 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0.102
2019 - Added new options values for Bit5 and Bit6.
