*morphdeletemvedgenodes
Deletes the selected mid-edge nodes from the edges of morph volume.
*morphdeletemvedgenodes entity_type mark_id
HyperMesh Tcl Modify Command
This command will remove the specified mid-edge nodes which govern the shape of a morph
volume edge. The edges will then be refit to follow the shape of the remaining nodes, which
may change the shape of the morph volume. Nodes at the ends of edges may not be deleted and
will be ignored by this command. The nodes to be removed may be specified either by the
nodes or the handles on those nodes.
Note: Updating the nodes for a morph volume will not
morph the registered nodes.
- entity_type
- Valid values are nodes or handles.
- mark_id
- The mark ID containing either nodes or handles. Valid values are 1 and 2.
Examples
To delete all mid-edge nodes in the model:
*createmark nodes 1 "all"
*morphdeletemvedgenodes nodes 1
To delete a handle and the underlying node from an edge:
*createmark handles 1 13
*morphdeletemvedgenodes handles 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
10.0
