*realizeengineeringentities
Realize engineering entities.
*realizeengineeringentities entity_type mark_id reserved
HyperMesh Tcl Modify Command
- entity_type
- The type of engineering entities to realize.
- mark_id
- The ID of the mark containing the engineering entities to realize. Valid values are 1 and 2.
- reserved
- Reserved for future use. Must be set to 0.
Realize mass entities with IDs 1 and 2:
*createmark masses 1 1 2
*realizeengineeringentities masses 1 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2017.2
