*adaptive_wrapper_leak_check_mc
Check leakage and generate 1Ds for the leak path for an adaptive wrap mesh control.
*adaptive_wrapper_leak_check_mc mc_mark_id entity_type mark_id
HyperMesh Tcl Modify Command
- mc_mark_id
- The ID of the mark containing the adaptive wrap mesh controls. Valid values are 1 and 2.
- entity_type
- In case the mesh controls do not have a base entity selection, then comps and elems must be assigned separately.
- mark_id
- The ID of the mark containing any base entity selections. Valid values are 1 and 2.
Examples
To perform a leak check on mesh control 2 by specifying components 20 and 21 as input:
*createmark meshcontrols 1 1
*createmark comps 1 20 21
*adaptive_wrapper_leak_check_mc 1 comps 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
