*morphmapedgestoequationoffset
Maps selected morph volume edges to the surface of an equation.
*morphmapedgestoequationoffset user_mark_id equation origin origin_id use_symmetry use_constraints project vector_id number_of_mid_handles offset
HyperMesh Tcl Modify Command
This command maps the handles on the marked morph volume edges to a function along the specified vector, equation surface normal, or normal to any attached shell elements (unusual for morph volume edges).
- user_mark_id
- The ID of the user mark containing the morph edges. Valid values are 0-3.
- equation
- String containing an equation f(x,y,z). The equation can contain x, y, and z variables but should not contain an equals sign. The surface of the function is located where the value of the function equals zero.
- origin
- 0 - Use global origin and system
- origin_id
- The ID of node or system specified in origin. Ignored if origin is 0.
- use_symmetry
- 0 - Do not use symmetry links
- use_constraints
- 0 - Do not use constraints
- project
- 0 or 10 - Project along vector defined by vector_id
- vector_id
- The ID of vector created using *createvector for the projection direction. Must be set to 1.
- number_of_mid_handles
- -1 - Do not change the handles on the edges
- offset
- The distance to offset nodes from the target.
Examples
To map edges on mark 0 to an equation (sphere of radius 10) with an offset of 1.2 using the global system along a vector leaving the handles unchanged:
*morphmanageedgemark 0 0 3
*morphmanageedgemark 2 0 1
*morphmanageedgemark 4 0 1
*createvector 1 1.0 0.0 0.0
*morphmapedgestoequationoffset 0 "x*x+y*y+z*z-100.0" 0 0 1 1 0 1 -1 1.2
To map edges on mark 1 to an equation (sphere of radius 10) using a local system along the line normal with 3 mid-handles per edge:
*morphmanageedgemark 0 1 3
*morphmanageedgemark 2 1 1
*morphmanageedgemark 4 1 1
*morphmapedgestoequationoffset 1 "x*x+y*y+z*z-100.0" 2 1 1 1 1 1 3 0.0
# Handle error
}Version History
14.0.110
