*meshtopologyadjust
Adjusts the mesh on selected surfaces to its boundary by moving nodes to the boundary, splitting elements or suppressing geometry edges or vertices.
*meshtopologyadjust mark_id flags
HyperMesh Tcl Modify Command
This command is intended to work with 2D meshes created by QI meshing, batchmeshing, element remeshing and manual editing tools. Very often such meshes have multiple elements intersected by the surfaces selection boundary edges. This command attempts to adjust the mesh on selected surfaces to its boundary by moving nodes to the boundary, splitting elements or suppressing geometry edges or vertices.
- mark_id
- The ID of the mark containing the input surfaces. Valid values are 1 and 2.
- flags
- A flag that controls the level of mesh adjustment to topology. Valid values are:
To adjust the elements for surface 143 with full adjustment to topology edges of elements edges shared with adjacent mesh:
*createmark surfaces 1 143
*meshtopologyadjust 1 3
# Handle error
}Version History
11.0
