*createfbdfilefromfbdsummarytable
Creates a .fbd file from an FBD summary table.
*createfbdfilefromfbdsummarytable filepath summPt_systemId summaryTable_name
HyperMesh Tcl Modify Command
- filepath
- The full name and path of the .fbd file to write.
- summPt_systemId
- The ID of the system to resolve the summation.
- summaryTable_name
- The name of the FBD summary table created by *createfbdsummarytable.
To write the FBD file to C:/temp/my_fbd.fbd using system ID 2 and
summary table
FBDSummary_Run1:
*createfbdfilefromfbdsummarytable C:/temp/my_fbd.fbd 2 FBDSummary_Run1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019.1
