*morphmaptolinevecoffset
Maps nodes to a line list along a vector.
*morphmaptolinevecoffset entity_type_nodes mark_id_nodes entity_type_handles mark_id_handles line_list node_list use_symmetry use_constraints project vector_id mode offset
HyperMesh Tcl Modify Command
Maps nodes to, or offset from, a specified line using the temporary shape created by *morphmaptshp and *morphmaptshpedge as a guide. Selected handles can optionally follow behind the morphing operation.
Nodes can be projected on to the line along a vector, normal to the line, or spaced evenly along the line (if the nodes belong to edge domains).
- entity_type_nodes
- Must be set to nodes.
- mark_id_nodes
- The ID of the mark containing the input nodes. Valid values are 1 and 2.
- entity_type_handles
- Must be set to handles.
- mark_id_handles
- The ID of the mark containing the handles. Valid values are 1 and 2.
- line_list
- The ID of the list containing the input lines. Valid values are 1 and 2.
- node_list
- The ID of the list containing any nodes to define input lines. Valid values are 1 and 2.
- use_symmetry
- 0 - Do not use symmetry (only option)
- use_constraints
- 0 - Do not use constraints
- project
- 0 or 10 - Project along vector defined by vector_id
- vector_id
- The ID of vector created using *createvector for the projection direction. Must be set to 1.
- mode
- 0 - If *morphmaprecalc has been used to calculate new influences
- offset
- The distance to offset nodes from the target. Not used if project is 2.
To project nodes on mark 1 normal to the lines on list 1 with an offset of 1.2 when not using *morphmaprecalc:
*morphmaptolinevecoffset nodes 1 handles 1 1 1 0 1 1 1 1 1.2
# Handle error
}Version History
14.0.110
