*detachallelements
Detaches elements from each other and from the attached structure, using the specified offset value.
*detachallelements mark_id offset
HyperMesh Tcl Modify Command
- mark_id
- The ID of the mark of elements to detach. Valid values are 1 and 2.
- offset
- The distance by which the elements should be offset from the attached structure.
To detach elements 10 and one layer of adjacent elements from each other and from the
remainder of the
structure:
*createmark elems 1 10
*appendmark elems 1 adjacent
*detachallelements 1 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
