*clearlist
Clears the specified list.
*clearlist entity_type list_id ?"by model" <model_name>?
HyperMesh Tcl Modify Command
This command clears the specified list.
- entity_type
- The type of entity on the list.
- list_id
- The ID of the list to clear. Valid values are 1 and 2.
- "by model" <model_name>
- The optional model to clear the list from. If not specified, the current model is used.
Examples
To clear the elements on list 1 before creating a new
list:
*clearlist elems 1
*createlist elems 1 3 4 5 6To create, query, and clear a list from nodes 2, 10, and 3 for model
model-2:
*createlist nodes 1 "by model" model-2 2 10 3
set my_list [hm_getlist nodes 1 0 model-2]
*clearlist nodes 1 "by model" model-2Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020 - Added new option "by model".
