*appendmarksolverdata
Appends a mark with entities of the given type that match a defined pattern of identifying information.
*appendmarksolverdata EntityType SolverNumber MarkID Arg1 Arg2 Arg3 Arg4…
HyperMesh Tcl Modify Command
- EntityType
- The type of entities to add to the mark. See details below for different entities supported.
- SolverNumber
- A unique number for each solver that HyperMesh interfaces with:
- 1 - OptiStruct, Nastran
- 2 - Abaqus
- 4 - Autodv
- 6 - PAM-CRASH
- 8 - ANSYS
- 9 - LS-DYNA3D
- 10 - Deform
- 11 - HFSolver
- 16 - Moldflow
- 18 - PAM-CRASH
- 19 - HyperXtrude
- 20 - Radioss
- 21 - Permas
- markID
- The mark ID to which the entities found by this command will be appended.
- Arg1, Arg2, …
- Various arguments that vary based on entity type.
| Entity Type | arg1 | arg2 | arg3 | arg4 | arg5 | arg6 |
| NODES | unused | attrib1 | value1 | ... | ||
| ELEMS | config | type | attrib1 | value1 | ... | |
| COMPS | Card Image/ Template Tag | attrib1 | value1 | ... | ||
| LINES | unused | attrib1 | value1 | ... | ||
| SURFS | unused | attrib1 | value1 | ... | ||
| LOADS | config | type | entitytype | attrib1 | value1 | ... |
| SYSTS | unused | 0-any definitioncode 1-coordinate based 2-node based (see below) |
0-any type 1-rectangular 2-cylinder 3-spherical |
| LOADCOLS | Card Image/ Template Tag | loadstepid | attrib1 | value1 | ... | |
| SYSTCOLS | Card Image/ Template Tag | attrib1 | value1 | ... | ||
| SETS | Card Image/ Template Tag | entitytype 1000-justrlink nodesets 1001-omit rlink nodesets |
0-any set 1-unordered 2- ordered 3-formula |
| PROPS | Card Image/ Template Tag | attrib1 | 3-formula value1 |
| Groups | config | type | ttag | loadstepid | attrib1 | value1 |
| Groups - rwalls | config=5 | type | ttag | loadstepid | geometrytype | motiontype (see below) |
| Plots | unused | attrib1 | value1 | ... | ||
| Curves | unused | attrib1 | value1 | ... | ||
| Blocks | Card Image/ Template Tag | attrib1 | value1 | ... | ||
| Mats | Card Image/ Template Tag | attrib1 | value1 | ... | ||
| Assems | unused | attrib1 | value1 | ... | ||
| Titles | unused | attrib1 | value1 | ... | ||
| Vectorcols | Card Image/ Template Tag | attrib1 | value1 | ... | ||
| Vectors | unused | attrib1 | value1 | ... | ||
| Equations | unused | config | attrib1 | value1 | ... | |
| Cards | Card Image/ Template Tag | attrib1 | value1 | ... | ||
| Outputblocks | unused | loadstepid | entitytype | attrib1 | value1 | ... |
| Outputblocks (elems) | unused | loadstepid | 2 | class (see note) | attrib1 | value1 |
| Loadsteps | unused | attrib1 | value1 | ... | ||
| HM_points | unused | attrib1 | value1 | ... | ||
| HM_splines | unused | attrib1 | value1 | ... | ||
| Sensors | unused | attrib1 | value1 | ... | ||
| Designvars | config | attrib1 | value1 | ... | ||
| Beamsectcols | Card Image/ Template Tag | attrib1 | value1 | ... | ||
| Beamsects | unused | attrib1 | value1 | ... | ||
| Optitableentrs | unused | attrib1 | value1 | ... | ||
| Optifunctions | unused | attrib1 | value1 | ... | ||
| Optiresponses | unused | attrib1 | value1 | ... | ||
| Dvprels | config | attrib1 | value1 | ... | ||
| Opticonstraints | unused | attrib1 | value1 | ... | ||
| Desvarlinks | unused | attrib1 | value1 | ... | ||
| Objectives | unused | attrib1 | value1 | ... | ||
| Controlvols | Card Image/ Template Tag | attrib1 | value1 | ... | ||
| Opticontrols | config | attrib1 | value1 | ... | ||
| Optidscreens | unused | attrib1 | value1 | ... | ||
| HM_tag | unused | attrib1 | value1 | ... | ||
| Dobjrefs | unused | attrib1 | value1 | ... | ||
| Contactsurfs | Card Image/ Template Tag | attrib1 | value1 | ... | ||
| Connectors | unused | attrib1 | value1 | ... | ||
| Shapes | unused | attrib1 | value1 | ... | ||
| Handles | unused | attrib1 | value1 | ... | ||
| Domains | unused | attrib1 | value1 | ... | ||
| Symmetrys | unused | attrib1 | value1 | ... | ||
| Solids | unused | attrib1 | value1 | ... | ||
| Morphconstraints | unused | attrib1 | value1 | ... | ||
| Hypercubes | unused | attrib1 | value1 | ... | ||
| Ddvals | unused | attrib1 | value1 | ... |
Examples
*createmark props 1
*appendmarksolverdata props 1 1 857 All Here the Property entities ("props") that use Nastran (solver "1") attribute ID 857 (from the ARG. Table) set to any value, are added to the mark.
*createmark props 1
*appendmarksolverdata(groups, 9, 1, 3, 1, 2389, 0, 97, 1, 4733, 0)For example, you can use this command to create a mark containing all the components in the model that use the LS-DYNA *PART_INTERTIA card image.
