*CE_CreateNodeOnSpotConnector
Creates a node on a spot line connector at a given position.
*CE_CreateNodeOnSpotConnector mark_id x y z
HyperMesh Tcl Modify Command
Creates a node on a spot line connector at a given position. This node can then be used to trim the spot line connector at that location. To create a node with a mouse click on a connector, the x, y, and z values should all be passed as -1.
- mark_id
- The ID of the mark of spot line connectors to trim. Valid values are 1 and 2.
- x
- The x position on the spot line connector.
- y
- The y position on the spot line connector.
- z
- The z position on the spot line connector.
Examples
To create a temp node on spot line connector 101 at (100, 50,
50):
*createmark connectors 1 101
*CE_CreateNodeOnSpotConnector 1 100 50 50To create a temp node on spot line connector 101 at a mouse click
position:
*CE_CreateNodeOnSpotConnector 1 -1 -1 -1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021
