*ME_ModuleOccurrenceInstancesSyncContents
Synchronizes the contents of one module occurrence to the specified target occurrences that share a common module prototype.
*ME_ModuleOccurrenceInstancesSyncContents src_me_id target_me_ids ?options?
HyperMesh Tcl Modify Command
Every module occurrence has an associated module prototype. A single module prototype may provide the base definition for multiple module occurrences, that is, a prototype of a wheel, might have four occurrences in a vehicle.
This command synchronizes a single occurrence with one or more additional instanced occurrences of a common prototype. It will clear any current contents of the target occurrences and copy/synchronize the contents of the source occurrence into the targets.
- src_me_id
- The ID of the source module which provides the content to be synchronized.
- target_me_ids
- The IDs of the target modules to receive the synchronized content (need to be enclosed in quotes if more than one ID is provided). Specifying a single value of 0 is a shortcut to target all other instanced occurrences that share a common prototype with src_me_id.
- ?options?
- List of input options, passed as a comma separated string enclosed in quotes. Valid
options are:
- excluded_entity_types=<type1> <type2> ... <typeN>
- A space separated list of module entity types to exclude from synchronization.
- copy_partrep_status=<value>
- 0 - Do not update the current rep and mapped/loaded rep status of the target occurrences.
- target_mode=<value>
- If specified, the command will calculate the target parts ignoring anything specified in target_me_ids.
- target_outputmark=<value>
- The ID of the user mark. Valid values are 1 or 2. If specified, the successfully synced parts will be placed on the specified user mark.
Examples
*ME_ModuleOccurrenceInstancesSyncContents 22 “” “target_mode=4, target_outputmark=1”*ME_ModuleOccurrenceInstancesSyncContents 22 “24 26 28” "copy_partrep_status=1, excluded_entity_types=props mats"Errors
# Handle error
}Version History
2020.1
