*morphconstraintupdateeq
Updates an equation type constraint for the specified nodes.
*morphconstraintupdateeq ntype nmark type mcon vec function distance ivec meth oid color
HyperMesh Tcl Modify Command
This command will update a constraint for the nodes on the mark which positions the nodes on or a specified distance away from the surface of the function. The function can contain x, y, and z variables but should not contain an equals sign. The surface of the function is located where the value of the function equals zero. The function will be positioned at the global origin if meth is set to 0. If meth is set to 1, oid will specify the origin node and the global system will be used for the x, y, and z directions. If meth is set to 2, oid will specify the local system to be used for the origin and x, y, and z.
type determines if the nodes move along the surface of the function, are bounded by the surface of the function, remain a set distance from the surface of the function, or maintain their original distance from the surface of the function.
To enable mesh stretching, add 32 to the type (thus 1, 3, and 5 become 33, 35, and 37).
- ntype
- Must be set to nodes.
- nmark
- The ID of the mark containing the constrained nodes. Valid values are 1 and 2.
- type
- 0 - Moves along the surface of the function
- mcon
- The ID of the morph constraint to update.
- vec
- The ID of the vector created using *createvector. Must be set to 1.
- function
- String containing a surface definition function f(x,y,z)
- distance
- Distance nodes must remain away from the surface of the function (type 1 and 3 only).
- ivec
- 0 - Project normal to function
- meth
- 0 - Use global origin and system
- oid
- ID of node or system specified in meth.
- color
- The color of the constraint. Valid values are 1-64.
Examples
To update a constraint where all nodes move along the surface of a sphere and are projected normal to the sphere:
*createmark nodes 1 "all"
*createvector 1 1.0 0.0 0.0
*morphconstraintupdateeq nodes 1 0 12 1 "x*x+y*y+z*z-100.0" 0.0 0 0 0 11
To update a constraint where all nodes are bounded by the sphere by a distance of 2.0, projected along a vector, and use a local system to orient the sphere:
*morphconstraintupdateeq nodes 1 1 12 1 "x*x+y*y+z*z-100.0" 2.0 1 2 1 11
# Handle error
}Version History
10.0
