*replacenodes_multiple
Replaces multiple nodes simultaneously.
*replacenodes_multiple sourcelist targetlist ?equivalence? ?midpoint?
HyperMesh Tcl Modify Command
- sourcelist
- The list of source nodes.
- targetlist
- The list of target nodes.
- equivalence
- Enable node equivalencing.
- midpoint
- 0 – Source nodes are moved to target nodes. (default)
Examples
Replaces nodes ID 1, 2, 3, to nodes ID 4, 5, 6:
*createlist nodes 1 1 2 3
*createlist nodes 2 4 5 6
*replacenodes_multiple 1 2Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2022.3
