*freeshapedesvarcreatewithmethod
Creates a free shape design variable.
*freeshapedesvarcreatewithmethod entity_type mark_id name method
HyperMesh Tcl Modify Command
- entity_type
- The type of entity used in creating the design variable. Valid values are nodes, elements, sets (nodal only), or properties.
- mark_id
- The ID of the mark of entities used to create the design variable. Valid values are 1 and 2.
- name
- The name of the design variable.
- method
- 0 - CLASSIC
To create a free shape design variable fsh1 comprised of nodes, with method
BLANK:
*createmark nodes 1 2110 3292
*freeshapedesvarcreatewithmethod nodes 1 "fsh1" 2To create a free shape design variable fsh2 comprised of a node set, with method
CLASSIC:
*createmark sets 1 "set1"
*freeshapedesvarcreatewithmethod sets 1 "fsh2" 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019.1
