*edgesmarkrestorejoints
Restores previously suppressed fixed points on edges.
*edgesmarkrestorejoints mark_id
HyperMesh Tcl Modify Command
This command restores previously suppressed (by using *verticesmarksuppress) fixed points on selected surface edges.
- mark_id
- The mark ID of input surface edges. Valid values are 1 and 2.
To restore fixed points on surface edge
99:
*createmark lines 1 99
*edgesmarkrestorejoints 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0.110
