*sethistorymemorylimit
Sets the maximum amount of memory that history states are allowed to use.
*sethistorymemorylimit memory
HyperMesh Tcl Modify Command
- memory
- The maximum amount of memory (in MB) that history states are allowed to use.
- 0 - Disables all history recording, including potential legacy use cases.
- -1 - Indicates unlimited.
To set the maximum memory 1000 MB:
*sethistorymemorylimit 1000
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
