*AE_AttachmentControlConvert
Convert an existing attachment control to a different config.
*AE_AttachmentControlConvert name config
HyperMesh Tcl Modify Command
- name
- The name of the attachment control to update.
- config
- The new config:
Examples
Update the rigid_attachment attachment control to a rigid patch:
*AE_AttachmentControlConvert "rigid_attachment" 2
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020
