*importbom
Imports a UDMXML BOM file into a given part.
*importbom file_name options
HyperMesh Tcl Modify Command
<option>=<value> options must be enclosed in quotes, but can be provided in any order.
- file_name
- The name and path of the file to read.
- options
- The string containing all the <option>=<value> pairs.
- importoption=<value>
- The import option as child, replace or merge.
- overwriteattribs=<value>
- Valid when importoption=merge.
- subsystem=<value>
- 0 - Do not import subsystem structure.
- target_part_hmid=<value>
- The HyperMesh part ID to be used as root for importing when importoption=child.
- target_part_udmid=<value>
- If target_part_hmid is not provided, this is the UDMID of the HyperMesh part to be used as root for importing when importoption=child.
Import UDMXML BOM under UDM part ID $udmid from file C:/temp/exportedbom.xml:
*importbom C:/temp/exportedbom.xml "importoption=child overwriteattribs=1 target_part_udmid=$udmid"
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019.1
2020 - Added new option subsystem.
