*pushtofront
Sets a visualization mode to keep certain entities visible in front of others.
*pushtofront entity_type mode
HyperMesh Tcl Modify Command
- entity_type
- The type of entity to control. Valid values are tags.
- mode
- 0 - Do not push to front (default)
To keep tags in front:
*pushtofront tags 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0.110
