*clearmark
Clear all entity IDs of the passed entity type from the specified mark.
*clearmark entity_type mark_id ?"by model" <model_name>?
HyperMesh Tcl Modify Command
This command clears all entity IDs of the passed entity type from the specified mark.
- entity_type
- The type of entity mark to clear.
- mark_id
- The mark ID. Valid values are 1 and 2.
- "by model" <model_name>
- The optional model to clear the mark from. If not specified, the current model is used.
Examples
To clear the components on mark 2 before creating a new
mark:
*clearmark comps 2
*createmark comps 2 allTo clear the components on mark 2 for model model-2 before creating a new
mark:
*clearmark comps 2 "by model" model-2
*createmark comps 2 "by model" model-2 allErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020 - Added new option "by model".
