*solidmap_solids_begin3
Initializes the line mesh parameters after resolving the density conflicts of the lines in the solid.
*solidmap_solids_begin3 solidmark=<value> elemsize=<value> <option3>=<value3> ... <optionN>=<valueN>
HyperMesh Tcl Modify Command
Initializes the line mesh parameters after resolving the density conflicts of the lines in the solid. Balances all the line densities (resolves all density conflicts), initializes the mesh parameters of these lines, and sets all possible source faces as mapped and the remainder as free.
Must be called before *solidmap_solids_begin or *solidmap_solids_begin2.
- dest_hint_mark=<value>
- The ID of the mark of the optional destination hint surfaces. Valid values are 1 and 2.
- elem_type=<value>
- The 2D element type when per face meshing parameters are not available:
- elemsize=<value>
- The default element size when the per edge/face meshing parameters are not available. This is a mandatory option.
- orthogonal_extrusion=<value>
- 0 - Make the reparameterization of along faces more orthogonal
- solidmark=<value>
- The ID of the mark of the solids to mesh. Valid values are 1 and 2. This is a mandatory option.
- src_hint_mark=<value>
- The ID of the mark of the optional source hint surfaces. Valid values are 1 and 2.
Examples
To initialize the mesh parameters of lines of solid 1 without giving any source or destination surface hints:
*createmark solids 1 1
*solidmap_solids_begin3 solidmark=1024 elemsize=2.000000 elem_type=2
*defaultremeshsurf 2 2 2 2 0 0 0 0 1 0 0 0 0
*solidmap_solids_begin 1 32896 2
*solidmap_solids_end
# Handle error
}Version History
2025
