*realizeentity
Realizes an engineering entity into solver data.
*realizeentity entity_type <select_type>=<selection> ?option1=<value1> option2=<value2> ...?
HyperMesh Tcl Modify Command
- entity_type
- The type of engineering entity to realize. Currently only supported for fields.
- <select_type>=<selection>
- The engineering entity to realize. There are several ways to provide the entity to be
modified. Only one option can be used at a time:
- id=<id>
- The ID of the single entity to modify.
- name=<name>
- The name of the single entity to modify.
Examples are provided within the subtopics of each supported entity type.
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
