*isolatesegments
Isolates segments.
*isolatesegments set_ids=<value> elem_ids=<value> face_indices=<value> ?consider_elems=<value>?
HyperMesh Tcl Modify Command
Isolates segments. A segment is defined using its corresponding set ID, element ID, and face index.
- set_ids=<value>
- The ordered list of set IDs from which the segments need to be isolated.
- elem_ids=<value>
- The ordered list of element IDs corresponding to the segments.
- face_indices=<value>
- The ordered list of face indices corresponding to the segments.
- consider_elems=<value>
- Flag to consider underlying structural elements during unmasking of the segments. Valid values are true or false.
Examples
To isolate segments with face indices 4 and 3 on element ID 78 from set ID
5:
*isolatesegments "set_ids={5 5}" "elem_ids={78 78}" "face_indices={4 3}"Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2022.1
