*surfacemarkremovepinholes
Removes pinholes.
*surfacemarkremovepinholes mark diameter coords arraylength
HyperMesh Tcl Modify Command
Removes pinholes.
- mark
- The mark ID containing the surfaces.
- diameter
- The upper-limit of the pinhole’s diameter.
- coords
- The ID of a double-array listing the center coordinates of the pinholes to remove, in the order x1, y1, z1, x2, y2, z2, x3, y3, z3.
- arraylength
- The array length.
Examples
To remove 3 pinholes from surface 471, using a radius of 5.0 as a
guide:
*createmark surfaces 1 471
*createdoublearray 9 1577.74 500.9 690.69 1580.8 502.6683.4 1583.8 504.2 676.207
*surfacemarkremovepinholes(1,5,1,12)The *createmark() and *createdoublearray() commands are required.
