*setanimationframe
Sets the animation frame.
*setanimationframe frame
HyperMesh Tcl Modify Command
This command the animation frame.
- frame
- The index of the animation frame.
Examples
To set the animation to frame 5:
*setanimationframe 5Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2024
