*modent_saverepresentation2
Saves the contents of a modular entity representation.
*modent_saverepresentation2 entity_type entity_id ?repkey=<value>? ?filepath=<value>? ?repcomment=<value>?
HyperMesh Tcl Modify Command
Saves the contents of a modular entity representation. If entity_type is subsystems, the representation will always be saved in HyperMesh database format (*.hm). When the representation already has a key and file path associated with it, those parameters are not required.
- entity_type
- Type of modular entity to save the representation of. Currently only supported for subsystems.
- entity_id
- ID of the modular entity.
- repKey=<value>
- The representation key. This is unique per subsystem.
- filepath=<value>
- Full path and file name of the representation file.
- repcomment=<value>
- The comment to add to the representation object.
Examples
Save the contents of subsystem ID 3 as a representation with key "crash5" in location
"C:/representations/Subsystem3_Crash5mm.hm":
*modent_saverepresentation2 subsystems 3 repkey=crash5 filepath=“C:/representations/Subsystem3_Crash5mm.hm”Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2023
