*hwct_synclibrary
Synchronizes library information from a connected library.
*hwct_synclibrary entity_type mark_id params
HyperMesh Tcl Modify Command
Synchronizes library information from a connected library. This includes information such as Major Revision, Study Revision and Library Revision.
- entity_type
- The type of connected library. Supported for parts and subsystems.
- mark_id
- The ID of the mark of entities. Valid values are 1 and 2.
- params
- A quoted, comma separated string, containing additional optional name=value parameters. Currently not supported.
Examples
Synchronize library related information for subsystem 2:
*createmark subsystems 1 2
*hwct_synclibrary subsystems 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020
2024 - Added parts to supported entity types.
