*removeincludes
Deletes the include files from the database, optionally removing all its contents as well.
*removeincludes include_ids={<value>} remove_contents=<value>
HyperMesh Tcl Modify Command
- include_ids={<value>}
- The list of include file IDs to be deleted.
- remove_contents=<value>
- If nonzero, then all the contents of those include files will be deleted from the database.
Examples
To remove the include files 1 and 2 from the database, and delete their contents as
well:
*removeincludes include_ids={1 2} remove_contents=1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2022.2
