*setelemparamcolor
Sets the color for a specified element quality parameter for elements violating the threshold.
*setelemparamcolor param_id color
HyperMesh Tcl Modify Command
This command is related to the element quality view mode. It sets the color for a specified element quality parameter for elements violating the threshold.
- param_id
- Specifies the element quality check parameter ID to update. Valid values are:
- 0 - min size
- 1 - max size
- 2 - aspect ratio
- 3 - warpage
- 4 - max interior angle quad
- 5 - min interior angle quad
- 6 - max interior angle tria
- 7 - min interior angle tria
- 8 - skew
- 9 - Jacobian
- 10 - chordal deviation
- 11 - quality index
- color
- The color to use. Valid values are 1-64.
To set "aspect ratio" color to brown:
*setelemparamcolor 2 28
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0.110
