*copymark
Copies entities from one collector to another.
*copymark entity_type mark_id name ?disable_fe_geom_duplicate? ?copy_elems_with_surf?
HyperMesh Tcl Modify Command
- entity_type
- Entity type to copy. Any collected entity type (aside from main/secondary elements) is valid.
- mark_id
- The ID of the mark containing the entities to copy. Valid values are 1 and 2.
- name
- The name of the collector to copy the entities to. The collector type is determined by the entity_type.
- disable_fe_geom_duplicate
- Parameter to disable FE geom duplicate option when copying elements. Valid values are 1 and 0 (default). If set to 1, the option fe_geom_dupl in the preferences will be disabled for the command and FE geometry will not be created upon element duplication.
- copy_elems_with_surf
- Option to copy elements along with surfaces. Valid values are 1 and 0 (default). If set to 1, elements associated to the original surface are copied and the newly created elements will be associated to the new surfaces.
Examples
To copy all elements in comp1 to
comp2:
*createmark elems 1 "by collector name" comp1
*copymark elems 1 comp2To copy all surfaces in surface_mesh component along with elements in
comp2:
*createmark surfs 1 "by collector name" surface_mesh
*copymark elems 1 comp2 1 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2022.3 – Added new optional arguments disable_fe_geom_duplicate and copy_elems_with_surf.
